my_gst95
- 569
- 10
- Nov 13, 2002
Sacramento,
California
I can't figure out which is the correct path since I just bought this 92 AWD FEDERAL car and need to smog it here in CA. The 2 lines that are confusing me are Yellow and the Green middle vacuum lines. Can anyone look under their hood or verify the correct vacuum path?
Here is what the PDF Shop Manual says:
Here is what under the hood says:
Lastly, the Thermo Valve on the thermostat housing is broke. Has anyone bypassed this valve and idled correctly? Currently since it's broke I've bypassed it and my idle seems to want to surge after warm up. This is the "Decel Surge", where the idle raises but since the ECU detects the throttle position at 0%, it cuts the idle off causing it to fall. When I cap off the TB vacuum nipples, the idle just constantly climbs and levels off at 2k rpms. Any help is appreciated.
