Vacuum at idle with big cams 272 280
marcmsj
1,414
14
Dec 20, 2004
Laurel, Maryland
What kind of vacuum are you guys seeing with your cams?
With my 280's, i'm only seeing about 4 inches and that seems way too low for me. We checked for vacuum leaks but couldn't find any but I'm pretty sure we're missing something.
So what vacuum are you guys seeing just so I can get a base line.
Vacuum should go down with bigger cams, but I'm pretty sure it's not supposed to be as low as what I'm seeing. I'm having a very hard time getting it to idle at all. Even idleing at 1000rpm, I have just about no vacuum, something must be up.
I got 12-14 inches of vacuum, with HKS 272's, when i first installed them the car ran like crap and idled at 900 with about 8 inches of vacuum, checked ignition timing and i was about 10* off, set it back to 5* BTDC and idles great!
15" of vacuum with my fp2's at 1000rpm idle. 4" of vacuum is WAY too low. You should be seeing 15"-12" of vacuum.
Do what epic904 suggested and then report back.
I rebuilt my motor and still pulled around 17 at idle. The only thing I can think of is that you have a vacuum leak somewere that you can't find. Did you break in the cams and valve springs by revving it at or around 2500 for a few minutes then varying it? What kind of vaccum/boost guage are you using as it might not be reading right either. I mean does it run real rough at idle because it should barely be running with that kind of vacuum.
It's an autometer mechanical gauge, It's been in the car for a while and never had any problems with it, it always read correctly. Everything has been broken in. And yes at 4 inches it's idleing very rough, almost stalling out and actually stalling at times. I'll double check for vacuum leaks and report back.
Verify compression,
If you have low compression it will do that too.
Low compression may be caused by cam timing as well, Guessing on a dsm costs alot of money.
Do a leak down test, make sure your not bleeding it out to somewhere else.
If its that low, I'd be checking for a "blown" out gasket... The car has to pull like crap!!
Did you by chance replace the intake mani gasket? You didnt use a paper one did you??
You gotta have a big leak.
Make sure the biss screw is set correctly also. That and ignition timing are the first things I look at. Did you ground the timing when you checked it? Are you sure your crank pulley isn't starting to seperate?
Motor is new doesnt mean that it is perfect. Do a compression check.
Dont overlook it, if it cant suck it in, it cant compress it, then it wont boost it.:beatentodeath:
since no one else is running the same cams I thought i would post, I also have the bc 280's with their springs/retainers I pull around 9 inches of vac at idle. seems normal on the bigger bc cams, a buddy of mine runs them on his colt and has around the same.
I will be kicking over my Talon within the next couple days, and this was actually a concern of my own when it came to vac pressure and larger cams on DSM's. I am used to the cammed, push rod, V8's that see good drops in vacuum pressure, but was wondering about DSM's.
I have a set of BC 272 cams sitting on my head that is ready to fire over, and I will post back within the next day or two when I see the vacuum pressure on my gauge.
My 272 idle around 17 to 22 depending on the rpms, and my good friend has the same cams as you and he sees 15-18... I used to have theat problem, mine was a leak in the hose running from the intake manifold to my boost gauge. It leaked under vac, but when I boosted her the hose would straighten out... good luck :thumb:
My autometer gauge is about 7" off from actual vacuum. I know what actual vacuum is because of my map sensor.
  • Wanted 6 bolt NT water pipe
    • chrisman287
