Vacuum and Boost Pressure
Benag
51
Apr 13, 2005
Atlanta, Georgia
I've done some searching but I wanted to try and make it specific so I know I'm running right. I have vaccum pressure at idle at about 19 psi and on decceleration at 22 psi. Is this normal? Also what is the normal boost max at stock?
Thanks a lot.
im just wondering, what boost gauge do you use? ive only seen gauges that show vaccum in mm/hg. or did you just convert it
Oh my bad, I meant 19 mm/hg. And it is an Autometer Sport Comp boost gauge I believe.
Would a boost leak cause a bad vac at idle? Mine is only like 12-13 mm/hg, and I'm pretty sure I have a boost leak because I get a cut at 4500-5000 RPM at WOT on a stock system..
