Using T25 water lines on 14b
Aphix
320
Aug 14, 2008
Salina, Kansas
So I have had my 14b turbo sitting on the bench waiting to get put in for about a month and a half (waiting for warmer weather) and I realize one of my water lines is missing. I believe its the water feed. I need to know if I can use the water lines from a t25 on my 14b or am I going to need to find another 14b line? I have searched and found some info on this but it was a little shaky and I want to confirm that this is possible.
I just found out that I am actually missing the return line. I was looking at the 14b and t25 return lines on extremepsi and they dont look interchangeable, they have different connectors on one side.
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Turbo Coolant Return Line Manual: Mitsubishi Eclipse 95-99 (T25/T28)
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Turbo Coolant Return Line Manual: Mitsubishi Eclipse 90-94 (14b/16g/20g)
The t25 return line will for sure work for the 14b?
Stick a screw driver in the water line to help you bend it, is also prevents kinking.
