UPPER CONTROL ARM BUSHINGS in REAR (95-99)
Patryk
368
Dec 29, 2002
Carol Stream, IL,
i need new bushing for the upper control ARM in the rear. THe one that says "Balljoint and Tie Rod End boots" but up top by the upper control arm. the one pointing up. I need a website.
DevilSperm said:
lower it without putting on a camber kit? i made my own with o-rings and heater hose....so far its held up 2 years and cost about 3 bucks refer to this thread http://www.dsmtuners.com/forums/showthread.php?t=39755
no i have camber kit on all 4 wheels. Perfect alignment and everything. Just started making a thump one day and i looked at it today and its ####ed.
if you can find aftermarket bushings, go for it..i couldnt find any unless it was a kit with a whole bunch of them for various parts of the car....you cant get OEM unless you buy the whole knuckle, thats like $200 or more...so basically what i did what take the little rod out and got all the old rubber off with a razor blade and some FIRE....then i glued heater hose to it....then on the ends of the rod i put about 4 o-rings starting with the smaller and getting bigger ones to fit around the previous one so basically is was one big flat o-ring...so far it has worked and its not clunking anymore...i did that about 2 years ago...good luck
That bushing is available from Prothane, but not (afik) from ES.
I don't know whether you can get the bushing individually, the
complete kit is about $200, so a new upright is far cheaper. I
think I paid ~$120 from Conicelli.
You can also Band-Aid it by making plastic spacers to take up the
gap between the upright and the A-arm, and other similar p[tions.
Charles
You can not buy them individually, believe me I tried to source one forever. I ended up buying the Energy Suspension rear control arm kit for like $60 from MrMoo at MachV.
www.dsmparts.com sells individual but it says 90-94
    • Sdcryan1
