Upgrading to Power Mirrors
douglaslovin
30
Oct 7, 2010
Conroe, Texas
I have a donor car that has power everything and I have the 99 eclipse RS with power nothing.
I already read the thread about putting power windows in and I can do that.
I could not however find a thread on power mirrors.
Is the same wires for power mirrors hooked up into the door wiring harness for power windows?
I will skip a few meals to make up the difference.
My main reason for doing this is because the plastic plate that covers the mirror knob is all busted + im lazy to fix it
:confused: so you’re going to possibly do more work by swapping to the power mirrors. :confused:
don’t know personally if all the wiring is already in your car for the mirrors or not but i know that with my 96 talon there are a couple of differences when it comes to things like w/factory alarm... easiest way to tell would be to pull the door panel and check for the connector... also pull the fog light/cruse switch panel and see if the wiring for the mirror switch is there... if not you will need to swap all the wiring harnesses as well...
i have power windows with non power mirrors and when i pull my panels last i had plugs already tucked away there for the power mirrors :cool:
