Upgrade Turbo
hypnotik
Aug 13, 2003
I currently have a 97 gsx, I want to bolt up a t3 turbo. What is needed to do the upgrade if any?
Thanks For Any Help :dsm:
T3 manifold,wastegate,oil/water feed and return lines,custom o2 housing and your intercooler piping my be needed to be modified.
Well... First off you need to update your car information and your car profile.
Is there any reason why do you want to go with a ''t3" turbo?
Assuming you have every bolt on mod in the upgrade path stg1 and 2.. Bullseye-power.com sell's a mitsu style housing that will bolt up to the mitsu manifold and o2 housing. I have their to4b turbo and love it. It was also a direct bolt on, But you need to block the water lines and then buy the oil feed/drain line kit.
Suddenly, a Big 16G/EVO3 B16G sounds soooo much cheaper. :laugh:
You can get an internally gated bolt on one from bullseye-power.com , Like I said. It is definatly not that more expensive then a big16g. I wish I wouldent have wasted money on a s16g then a b16g and then finally went with the t04b.
1993eclipseGS said:
Assuming you have every bolt on mod in the upgrade path stg1 and 2.. Bullseye-power.com I have their to4b turbo and love it. It was also a direct bolt on.
There's only one reply on that turbo on the website.Is it yours?
If not, you should.Need more feedback on the Bullseye site. :)
