mr2gixxer
- 33
- 0
- May 14, 2004
San Leandro,
California
Well here's a list of things that I did to my and still it will have a hard time starting up and numerous "clicking sounds" coming from the center counsel areas where the ECU is at:
-New Spark Plug Wires
-New Spark Plugs
-New fuel filter with B&M Fuel Pressure gauge.
-New Walbro 190 lph fuel pump
-New Engine Coolant Temp Sensor
-New Air Filter(hacked air can and honeycombs still in place)
-New Bosch 02 Sensor
-Replaced ECU with a know good one
-Getting fuel Pressure
-Getting Spark
-No Codes illuminating(check with homemade LED Light)
-Compression is at 145 across all 4 cylinders.
What else would cause a car have a hard time starting up if not at all? When it does start up, it will idle really sporatic, stock boost gauge will as well, and there is this clicking sound where the ECU is at. Could it be a bad Fuel pump relay? Where is that located? Also I hear of a ground strap that connects to the ecu, I didnt noticed any other than the 3 bolts that connect the ecu to the brace. Also after the car is warmed up, the car drive and idles fine. Let me know your help is greatly needed. Thanks.
-New Spark Plugs
-Getting Spark
