For Sale Updated Parts list for sale!!
dacowgod
Supporting Vendor
451
280
Feb 3, 2006
Morgantown, West Virginia
1g TRE/PAR Dogbox with QM twindisc - Has 5th Gear option, 300m Output shaft and Clutch is like new with .250 discs 6800
Magnus/PAR Dogbox 97-99 Ratio w/ 6 bolt awd QM Clutch w/ 1" hubs - Clutch is gear drive and has .244 Thickness remaining on discs. 6300
1995 Mitsubishi Eclipse GSX - Automatic AWD 3850
1993 Eagle Talon TSI AWD - 5 Speed 3800
1995 Eagle Talon TSI Automatic 3800
Brand new DSM BSFab Twin Scroll T4 6466 Combo - Includes Manifolds, Wastegate, Dump Tubes and Turbocharger all Brand new! 3250
PTE 6870 T4 Twin Scroll Kit with Mani Gates and more! 3000
Stoutly Built 6 Bolt Shortblock - Manley/Wiseco/Kiggly - Made 812 AWHP Without sneezing- SS Orings with .007 Protrusion, 1/2 Filled Water Jacket - Less than 200 miles total on shortblock! Deck down includes pumps and pan!. 3000
Very Clean 1995 Mitsubishi Eclipse GST (AWD Converted) Rolling Chassis 3000
Very low mileage Built 6 bolt short block with Manley HD Pistons/Manley Turbo Tuff combo 2400
Brand New Precision 6870 .96AR Vband turbo 1900
Built 6 bolt shortblock - Eagle Rods Wiseco Pistons - New copper O-rings in the deck! 1800
EVO Roller No title LOW Miles No Rust 1800
PTE 6466 Gen-2 DBB T4 Turbocharger 1750
Built 6 bolt shortblock 1650
EVO 8/9 Darkfab Twin Scroll T4 Exhaust Manifold with freshly rebuilt PTE 6765 Turbo 1600
Driveshaft Shop 2g Level 5 Rear Axles 1500
Carbonetics 2g Carbon Fiber Doors w/ Power Windows 1300
1998 Split Thrust Long Block - Refreshed 1250
BSFab V-Band Bottom Mount Exhaust Manifold(T4 equivalent V-band) 1000
Precision 6766 Turbocharger - .82 AR T3 Turbocharger (Journal bearing) 885
Built 1g Head - Supported 812 AWHP 850
Evo 8 / 9 Rear Differential - only 24,500 original miles! 800
1995 Mitsubishi Eclipse GST(AWD converted) 800
EVO 8/9 Sweitzer SMIM with Boomba 75mm Throttle Body 775
Refreshed Holset Super HX40 with Billet Wheel 775
2g #7 Precision Torque Converter 750
2g D2 Coilovers 675
Comp Turbochargers Billet 6765 T3 Journal Bearing Turbo setup 675
MagnaFuel 750 Mechanical Drive Electric Fuel pump 650
2g DSM K-Sport Coilover Set 625
EVO Brembo Brakes - Fronts and rears 525
Waterman Mechanical Drive Fuel Pump 500
Genuine MHI Small 16g turbo 500
Fuel Lab "Prodigy" Fuel Pump 475
Brand new BSFab 3" Vband Downpipe 450
Kelford 284/284 High Lift 450
2g IPT Restalled Converter 425
EVO 8/9 Sheepy 850 HP Intercooler core 425
EVO cluster with 24551 miles 425
HKS 264/272 Cams 400
Ported Garrett T28 Turbocharger 400
FP3 Cams - DSM 400
EVO 8 / 9 Rear Axle Pair - Only 24,500 Miles 400
2g Tokiko Illumina Adjustable Struts with Tokiko Red Springs 400
EVO 9 GSC S2 cams 400
Remote Tuning - 'Advanced' ECUFlash 400
DSM FP1 Cams 385
Kinectic/SBR 2g "short route" FMIC Core 350
Used Working EVO ACD Pump 350
2g FWD 5 Speed manual Transmission 350
Remote Tuning - 'Advanced" ECMLink 350
1g 4 bolt manual rear diff w/ axles and cups 325
EVO 8 HKS 264/272 Cams 325
EVO 8 HKS 264/264 Cams 325
FIC "EasyTune" Box 325
FIC 750cc Hi-Z Injectors 325
ID 725cc Hi-z Injectors 325
AFCO Dual Pass aluminum Radiator 325
2g "Euro" Tail lights 325
DSM Sparktech Coil-on-Plug (Standard Version) 325
Aeromotive Pro Series Adjustable Fuel Pressure Regulator 300
Yellow evo 8 9 trunk lid with spoiler 300
EVO 8 Blue Cloth interior - Fair Shape 300
Remote Tuning 'Simple' - ECUFlash 300
Skunk 2 pnp Coil on Plug for evo 8/9 265
PTE Low-z 1600cc Fuel Injectors 265
2g Tokiko Blue Struts with tokiko red springs 250
2g LSD Rear Axles - Both Sides 250
Remote Tuning - "Simple" ECMLink 250
Forced Four 100.1 Shift Box 240
1g JMFab Small Battery Kit w/ Oddessey PC680 Battery 240
Fluidampr Crank Pulley 235
Brand new Tial 38mm MVS Wastegate - Purple 235
Avid Racing Tuner Series 1g dsm Engine Mounts 225
HKS EVC EZ2 Boost Controller 225
Coil on Plug setup with 300m coils 225
2g Manual LSD Rear Diff 225
Polished valve cover with -12 weld in vent 225
Black Tial MVS 38mm Vband wastegate with clamp 225
2g Automatic LSD Rear Differential 225
Evo 8 steering wheel has wear on top 200
Oem evo 8 rear bumper 200
Black evo 8 9 trunk lid has holes for spoiler 200
EVO SSL Amp and Subwoofer 200
Yellow driver side fender 200
EVO 8 / 9 Cusco Rear Sway Bar (25mm) 200
EVO 8 / 9 Exedy Twin Disc - Needs Rebuilt 200
2g Manual NON LSD rear diff 200
Oem EVO 8 Tail lights 200
Evo 8 valve cover 200
Dynarc Fab catch can for 2g DSM 2 - 8an Fittings and 1 -10an Fitting 200
ARP 'L19' Head Studs for a 7 bolt 200
Automatic Transfer Case - 91-96 Ratio 200
A1 Technologies 6 bolt head studs 190
Cleaned and tested 880 CC PTE Injectors 185
FIC 750cc Injectors 165
Brand new Dejon Tool Non recirc intake pipe 155
Front passenger side fender evo 8 9 150
EVO 5 speed shifter base and cables 150
EVO 8 / 9 Dashboard w/ Passenger side airbag 150
23 Spline 91-96 Manual Transfer case 150
22 Spline Manual Transfer Case 150
Blacktop CAS with Frontline Fab cover 150
Tial 50mm BOV - Gold 150
Fuel Lab AFPR - Purple 130
Tial F38 2 bolt wastegate 130
Powdercoated Cherry Red "Hyundai" badged 4g63 DSM Valve Cover 125
EVO Steering Wheel - No airbag 125
Tein Lowering Springs - Evo 125
Fuel Lab AFPR 125
AEM 50 PSI Boost Gauge 125
EVO 8 / 9 Carbon fiber dash inlay 125
2g shifter and shift cables 125
ACT 2600 clutch cover 125
AEM Wideband Kit 125
ACT 2100 Pressure Plate 125
Brand New OEM Mitsubishi MLS Head Gasket for DSM 120
Black Magnus Fuel Rail 120
Jay Racing 1g Alternator Relocation Kit 105
Red Perrin Fuel Rail - EVO 100
Innovative Digital Boost Gauge 100
2g dejon tool long route upper intercooler pipe 100
83k mile 1990 DSM Cluster 100
2g megan racing shifter with base 100
Rexspeed Carbon Fiber EVO Armrest Cover 100
CRACKED! Valve cover with -10 an fittings 100
Genuine Greddy Type RS Bov 90
DSM 450cc Injectors 90
Dejon 3" intake pipe 85
Onsoku DSM Cam Gears 85
1g non abs front lines and prop valve 85
2g non abs front lines and prop valve 85
AEM 5 Bar Map Sensor 80
EVO 8 / 9 Exhaust Manifold 75
2g black airbag 75
97-99 Manual Halfshaft 75
1g throttle body with sensors 70
Braille Small Battery tray 65
MSD Digital Window Switch 65
Evo 8 front floor mats 65
2g awd rear trailing arms with red urethane bushing 65
2g gauge cluster 65
2g throttle body with sensors 65
6 bolt water pipe - heater core deleted 65
3g - Revised "No Tick" Lifters 65
Lightly used Greddy Kevlar timing belt 55
GSC Race Shaft 55
VERY LIGHTLY USED OEM "Nylon Reinforced" Timing Belt 55
Oem Harmonic dampner 50
EVO Lower Control Arm - Passenger Side Front 50
EVO Control Arm - Driver Side Front 50
Red Perrin Crank Pulley - EVO 50
Air horn kit! 50
7 bolt forward facing oil filter housing 50
6 bolt oil pan 50
2G TCU 50
2G Exhaust Manifold 50
Healthy 2g Knock Sensor 50
Used Gates Kevlar Timing Belt "Blue" 50
Standard 6 bolt ARP Head Studs 50
ECMLink v3 GM Maf wire 50
Good Used Saturn Alternator 50
Blox Evo 8/9 front rollstop 50
TurboXS Boost Controller 45
1990 style bolt oil filter housing 45
1991-1994 cluster 45
EVO - Passenger side inner axle 40
EVO - Driver side inner axle 40
Old school turbonetics wastegate 40
6 bolt oil filter housing 40
2g GST Fuel Sender 40
Shurflo Methanol Pump 40
EVO 8 \ 9 Aluminum Underdrive Crank Pulley 40
Unorthodox Racing Aluminum Crank Pulley 40
XSPower Ebay T3 Exhaust Manifold and Wastegate 40
Shift box gear display 35
2g Water Neck / Thermostat Housing 35
Blitz Full Auto Turbo Timer with 1g pnp harness 35
2g Manual Speed Sensor 35
HKS Turbo Timer 35
OEM DSM Spark Plug Cover 35
1g Water Neck / Thermostat Housing 35
1g Green top CAS 35
Walbro 255 fuel pump 35
Dsm power transistor ptu 35
2g Throttle Position Sensor 30
2g Auto Speed Sensor 30
Greddy Turbo Timer 25
EVO Spark Plug Cover 25
Good 1995-1996 MPI relay 25
2g alternator tensioner arm 20
2g AWD manual starter plate 20
Vibrant Racing Vacuum block 20
Throttle Body FIAV Block-Off plate 20
J pipe for 14b 16g turbos 20
Gold Spark Plug Cover 20
2g Dash Surround Dual Gauge Bezel 20
Taboo Speedshop Extended Slave rod for DSM 15
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
