DsM KiD4
- 223
- 0
- Dec 25, 2006
salinas,
California
THERE is so many types of RTV what are their differences. i went to napa today and i saw ultra; grey,black,blue,and orange?
i think im going to go ahead and use GREY on my oil pan without a gasket. also while i was looking at http://permatex.comI used Mopar black on my transmission and oil pan. Never had problems with either.
UltraGray is the correct replacement for the factory specified RTV in the service manual for the pan and rocker cover.
Do not use RTV on the waterpipe. The o-ring does the job of sealing the waterpipe to the pump housing and doesn't need anything else. The RTV will reduce it's ability to seal and flex. It can actually create ways for the coolant to leak. Make sure that the water pipe is free of any corrosion where the o-ring sits and that the o-ring is lubed with coolant before putting the pump on so it isn't cut or torn.
Steve
i dont think my water pipe has any corrosion so that cant be a problem. if what he stated above is true, what else can i do?Steve is absolutely correct (as Mitsu manual will verify) but he forgot to mention the following (which is also in the Mitsu manual):im not trying to be rude, but does anyone agree with that? ive tried lubing the o ring with coolant before installation and it still leaksi dont think my water pipe has any corrosion so that cant be a problem. if what he stated above is true, what else can i do?
One common source of a water pump leak is the o-ring not installed properly. You must replace the o-ring in the crossover inlet pipe by putting it on the pipe end first, coating with coolant, and then insert pipe with o-ring into water pump – do not put the o-ring into water pump first as it will not seat properly and will leak.
