typical problem, input requested
jmackisback
52
May 14, 2004
Richmond,
Hi there. I noticed recently that when i hit boost it feels like n/a power levels. There is very little pull. The autometer gauge still shows normal boost for the most part with it spiking higher than usual occasionally. I have boost leak tested to no avail
so this car was working fine, youve owned it for a while, then ond day it just went gutless?
its always gutless now? not intermittent at all?
there cant be very many causes for it to have normal boost and no power, no bucking or missing. you already did boost leak....
you change anything recently?
im not sure but if your fuel pressure is low wouldnt that cause your engine to knock like crazy and pull all your timing?
just making suggestions
im assuming its running smooth on all four, im sure youd know the differrnce, but if an injector clip falls off its pretty obvious, runs pretty rough, makes na power levels( actually probably still better than na)
