Types of spark plugs ???
sickcivic05
Jan 20, 2006
bellingham, Massachusetts
I tried searching for the answer to this and turned up nothing for my particular application. I recently bought a 92 Laser turbo awd, i did all the free performance upgrades and was wondering the the best spark plugs were . The car has 168,000 on it and it is completely stock.
Thanks in advance, Craig
The only plug for you now would be the NGK BPR6ES's. Put nothing else in till you upgrade a bit and turn the boost up. Then you will run a slightly colder plug the NGK BPR7ES's. Good luck enjoy the car
Also make sure to gap them to .28 we dont want you studdering, and backfiring under boost.
This is right except .28 is too big, try .028. :p
Stock to 7psi NGKBPR6ES and 17+psi NGkBPR7ES. Please use the search function as this has been asked countless times with pretty much just one answer.
