Type RS Recirc.
cybertrip
Mar 9, 2005
Waynesville, Ohio
Ok i am wanting to get the Greddy Type RS BOV i have heard great things about it but it says optional recirc kit but i cant find anywhere that sells, it any one know where to get it
I called Greddy like a week ago and they said they just got them in here at the states. Also theres going to be 4 diffrent sizes out, so mu guess is they will be out soon everywhere.
this is just my daily driver so porb no more than 16-18 psi i have my awd that will be running high boost.
i just bought the rs a couple weeks ago and im needing the recirculation kit too. the guy i bought it from is supposed to be ordering me one this weekend. try revhighonline.com, 321-945-3333, ask for kyle.
4G63 For Me said:
If you plan to run 25 PSI or more, I'd suggest going with a different BOV.
not true, that's true for the type-s only, the RS has a 40mm valve as apposed to the type-s' 37mm valve, theres been no test on it yet but it will hold more than 25psi
I've heard the limits of the Type S are around 22 PSI, and the Type RS was designed to hold 10% more boost.
Not to mention I run one and haven't been able to achieve over 26 PSI. Usually it hits around 24 and doesn't go higher.
But since you are only going to run in the teens, the RS will be great.
When I boost leak test my car, my RS holds over 25 pounds without leaking on a soft setting.
