Two problems----Need Help Please!!
bOOTh_000
51
Dec 27, 2003
Calgary,
hey everyone,
my 1992 esi is overall a good car but has a couple issues.
The first one is when i turn to the left there is a clicking sound that happens around the corner. Is this the cv or something else. How much would that fix approx. be.?
the second is the car will hesistate on acceleration like its misfiring at around 1100-1400 rpm in most gears...what could this be?
thanks alot, john
First. Yes, it's likely an axle. Just replace the whole thing. They are inexpensive.
Secondly, most likely it's plug wires. Check them for little white spots on the parts that go into the heads.
Both very common.
Good Luck
dudes right. mine clicks check your left front CV joint. I bet ten bucks it's popped. Mine clicks and it's completely destroyed. and as for misfiring, he's right as well, either spark plus, or wires. haha I just fixed both these issues not two days ago LOL
the rebuilt axles are cheap..
with the plug wires,just get a ngk set an grab some new plugs at the same time...and cal it a day.
