Resolved Turn signal socket/connector
sleeperhemi
82
Sep 22, 2012
White Plains, Maryland
Hi folks. I'm sure this is posted here but I haven't come across it. I am looking for the front turn signal socket/connector that attaches the body pigtail to the actual headlamp housing connector the bulb twists into. Pigtail clicks into that. Anyone have a part number or who sells it? thanks
Solution
Thanks guys. Actually I went to the dealership just to see what they cost and how hard they are to get. I got 2 of them for $9 each.
The one I took off the car was in great shape but new bulbs would never light up and signal didn't work. Just put in a new one, fixed. Had to be a connection inside the socket. Thanks for the offers tho. Much appreciated. I tell you what I am looking for if anyone has it, the drivers side fog light assembly. The glass is cracked in mine and retailers around here want to charge almost $140 each and junk yards aren't far off that. Thanks guys
whats going on with yours? I had a problem with one of mine, turn signal would intermittenly go out with a good bulb. I found out that one of the contacts, threw years of use, wasnt making a proper connection. The electricity would arc from the contact to the bulb base melting the contact area. All I did to fix it was to put a small ball of solder on the worn out connection, thus making a more solid contact area. So far its been about 4 years and no problems. Hope this helps out some.
This has just happened to mine I noticed. Thought the bulb was bad so I replaced it and nothing. I checked for power and there was but I noticed that the connector itself was cracked.
Best way to get one is pay Blurred Talon his shipping or just run to the salvage yard which should only be like $3
Solution
I know this was forever ago, but did anyone ever get the part number for this? I am in need of two of them.
