Turbonetics Turbo What to expect?
SleepingTsi94
261
Apr 24, 2006
Corn, Iowa
Got this a turbonetics turbo from a friend. Called up treadstone to see what turbo it was. This is what they gave me.
Its a stage 2 .48 turbine, and either a 50 trim or V trim compressor wheel
50 trim will have larger E comp cover, while V trim will have smaller B comp cover
What can I expect with this turbo? Is it to small? What psi should I able to push it to? Or should I sell it and invest in a different turbo.
That is one big ass turbo (to small. Are you serious) if its a 50 trim than you can do well over 30 psi. Now wether your car can support that is a different story. I would get some kind of filter to go over that you don't want to suck something in and screw it up.
Looks like an e cover...
That turbo will make enough power for a street/dd car. Only thing is you should probably get a manifold instead of using an adapter plate...or get a mitsu style turbine housing.
You gonna need to make a custom downpipe if you use the non mitsu turbine housing.
