turbo
speedy16
Feb 7, 2006
Nebraska city, Nebraska
will a t28 turbo replace a t25 without much problem thanks for your time
ok so would it be a problem if the aftermarket bov doesnt recuirculate just long enough for me to get it home or will this cuase problems its about a 3 hour drive???
Huh? What does upgrading to a T-28 have to do with not being able to recirculate your BOV?
Regardless, yes its fine if you vent your BOV for the drive home. It won't damage anything.. you'll just be running a little rich.
i guess iasked they wrong question what is need to recerculate the bov
unless you are using something that cant be re-circulated then you should do so untill you have a blow through set up. Some people still do it after that so they don't loose the spool of the turbo.
Your stock recirculation hose should work assuming the BOV is designed to be recirculated. Really it all depends on what kind of fitting is on the end of the BOV.
If you have one that looks like this, you'll be able to recirculate it just fine...
On the other hand, if you have the XS BOV that has the big horn on the outlet like this...
... then you're going to have a hell of a time recirculating it. You'll need to buy an adapter (assuming they make one for the XS BOV) or go with a different blow-off valve entirely.
Common sense stuff really... I'm sure you get the picture. :thumb:
