2G Turbo Upgrade?
stealtheclipse
May 21, 2005
CHALMETTE, Louisiana
hi i want to upgrade my 16G turbo to something bigger like a 50 trim what kind of turbo should i get that would make awesome numbers with the current mods i have.... i was lookin at a T3/T4......? :talon:
UPGRADES:
Engine:
2.0 Liter Turbocharged
K & N Air Filter
Injen Air Intake pipe
16G Turbo w/j-pipe
Turbo XS Manual Boost Controller
Greddy Upper and Lower I/C Piping
HKS SSQV BOV
65.5mm Ported & Polished Throttle Body
190 Walbro Fuel Pump (w/rewire kit)
Polished Aluminum Valve Cover
Pacesetter Tubular Ported Exhaust Manifold
Ported 2g O2 Housing
Megan 3inch Downpipe w/Cat eliminator
Thermal R&D 3inch Cat-Back Exhaust
Drivetrain/Transmission:
Exedy Stage 3 6-puck Clutch
Exedy Stage 3 Pressure plate
Fidanza 8lb Flywheel
Extended Clutch Slave Cylinder
Under-Hood Bearing Shift Kit
Fidanza Short-Throw Shifter
(Just did a full transmission flush) :talon:
Still have those RC 800cc injectors? You're not going to be going anywhere fast with the stock 450s. Also going to have trouble putting down big numbers on the stock SMIC.
Try this thread or this thread ;)
What about a turbonetics t3 turbo?? And what bout all the specs like I looked at it on arp turbos.com and it was a lot of different trims,bolt patterns,ect I need help with all of that.....not a big turbo expert..
I would recommend searching... because that's what a moderator is going to tell you right before they close this thread. Usually people get the T3/T4 combo for their DSMs. Just type in "50 trim" or "60-1" or whatever into the search box and start reading. You will soon learn a lot about turbos.
Also, when are you getting that 1996 TSi? Or did you buy it already?
