Turbo turbine housing... sound good?
$lacker
33
Mar 2, 2003
The GReddy exhaust housing on my 25G kinda really sucks... so I'm considering picking this up... saves some money too because I wouldn't be buying an external gate ($$$$$). I'll definately be going for an external dump though. I'm looking to have all the *parts* necessary to support 500hp+ (In other words I'd like to never have to upgrade this housing again)
$220USD + shipping, good?
"Tired of cracks in your old rusted out Turbine housing? These exhaust housings are cast from a High Grade Steel, a step above the iron housing from Mitsubishi. Dont want to pay to have your stock housing hand ported? Our housing is cast to match the upgrade 7cm manifold gasket. Want to increase your flow without sacrificing spool up? Our conical shaped entry gives you the flow of an 8 cm housing will maintaining the throttle response of a 6/7 cm stock housing. Tired of boost creep or dont want to go through the hassle and cost of external wastegates? Much larger than stock, this 1.5" or 38mm flapper is adequately sized to regulate boost up to 650HP (with the proper size cartridge). Internal Wastegate included with enlarged flapper and wastegate hole. External Wastegate option also available at a discount. Adjustable Lever position for multiple actuator applications. Street/Strip A/R ratio designed for maximum throttle response and flow numbers to operate in the 300-600+ HP range. Our Mitsubishi Style Turbine housings are machined to the exact specs of the OE TD06H Turbine wheels. Direct replacement for your Frank, FP Red or any turbocharger with a TD06H turbine wheel. Direct replacement for the Galant VR-4, Eagle Talon, Plymouth Laser and Mitsubishi Eclipse."
