Turbo Trix
I have no experience with that downpipe, but if you're still shopping around for downpipe's, any thing that mates up with the stock cat or the stock piping after the cat should fit. The Thermal bolts right up to your stock exhaust so you know the flange is still where most all aftermarket pipes assume it's going to be.
Of course if you want to run a full 3" exhaust there's going to be a little bit of fabrication needed. Have you seen the part where your thermal necks down to mate with your stock cat? You'll want to hack that part off and weld in a bit of 3" pipe and/or flange if you want your entire exhaust to be 3". So if you plan on doing that, it shouldn't really matter if your downpipe is a little off as far as length. You can fix it when you hack off the neck down part of your thermal.
