turbo to manifold studs?
i have the knock off version of the dnp and i got all my studs (i used bolts) at autozone. i think the tread pattern is Mm8x1.25. just take ## mannifold there and find some that will be able to slide past the runners. u should be good to go.
Yes 8mm x 1.25 pitch. Then there is 2 larger studs that I believe are 10mm x 1.25 I reccomend getting HIGH GRADE studs. Like grade 8 zinc coated studs. Then I use Anti seize compound on them.
Those cheapo white metal weak bolts could seize in the hole and break off when you go to remove them.
I usually can get anykind of bolt or stud from my local True Value Hardware store. You wont find anything useable at Home depot or Lowes...Those are garbage bolts. You need to find a small Hardware store. They should have studs in those sizes and in High Grade.
