Turbo timer help
Surprise, surprise. No instructions. Or are they just in Chinese?
And the turbo timer is practically useless unless you come boosting all the way up to your parking spot then immediately shut the car off. Just a minute or 2 of "normal" driving lets it cool down enough. Your turbo is water cooled. You really don't need it.
Here's this for the MBC:
http://www.dsmtuners.com/forums/att...7701-help-manual-boost-controller-bleeder.png
I hooked it up, I looked up a wiring diagram and the wires were all completely different colors except the solid blue. The red went into the white, the green went into the black/white one and the blue went into the blue. I turned the ignition key, have power and all seems to check out (havent been able to turn on the car since it has no piping or an intercooler, waiting til tomorrow to hopefully get it on since it took me a little over 2 hours to take off the bumper). I also hooked up the O2 sensor and the ground the ECU ground, that checks out for now. Hopefully its all installed correctly.
As for tomorrow I have to push back the power steering cooling lines and install the new front mount, wish me luck since I have an universal piping kit. I'm going to use some of the old pipes (including one the those black cloth/silicone ones that I found laying around). I'm hoping that helps a bit, if not, I can see myself already hating life for having to cut those pipes... and of course cut the bumper as well if needed.
So i had that same kit before and it doesnt work good at all, just more words for the profile upgrades. Anyways that turbo timer will work for the timer and the e-brake safety switch and i think the battery but the A/F or o2 wont work. Another thing you should know is that the fake turbo timer will give you a short and your battery will die if you dont drive for 2 days, its like some poor design or something and sometimes the lights will flicker when you first start it up. because after i replaced it with the real 1 the problem went away.
The MBC is the worst thing ever. It does nothing.
I saved up and got the real Apex integration timer and the Hallman pro rx mbc.
I learned to do it once and do it right.
