Turbo return line
JM90gst
43
Nov 5, 2009
Centra Coast, California
I have a leak in my oil return line off my turbo. There seems to be a hole about half way down it. I found this out because any time i make boost i blow oil onto my exhaust and the return line is only saturated starting half way down it. I am broke and cant find one in my junkyards so i was wondering if and how i could modify my stock broken on to work. Any insite helps. Thanks.
You could cut off the area that has a hole and use a rubber hose with some clamps until you get a replacement. I would go easy on the boost if you did that type of fix,as it would only be temporary.
I've been using a hose on my return line for a year and a half and it hasn't leaked yet. From that section at least.
Try a stm free shipping around 60 bucks, i had mine break, and its not worth it to me to try to repair that piece. Main reason for my Extensive clean up this winter, leaked oil everywhere, broke on a trip. Nursed her home.
