Turbo or Engine oil leak??
LKWTSI
601
10
Feb 7, 2008
Lake Wylie, South Carolina
My 90 Talon, just started to blow a little puff of oil smoke (blue) from the tail pipe. Here's the symptoms, anyone got a guess if this is the turbo or a piston ring leak?
Starts good, hot or cold, small wisps of blue from exhaust. accelerate from a standstill and cloud of blueish smoke then nothing as you accelerate onto boost very small trace of smoke to nothing. As you let off boost and coast, nothing for a little bit until you either go back on throttle (cloud of smoke, then nothing) or come to stop and nothing for about 30 secs then small wisps of smoke which clear again as you accelerate.
Going out to pull plugs, but was wondering if this is the oil supply to the turbo or oil leaking past piston rings. Going to do a compression test this week end and see what I get.
Anyone had similar problems before?
Thanks for the replies.
:confused::confused::confused:
No worries, found the prob' damned turbo shaft wobbles more than a wobblehead. inlet blades are completely broken and gouged. Anyone got a nice 14b they want to sell??
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
