Turbo opinion and streetability??
Slippi84
4,454
20
Jun 8, 2005
Cinnaminson, New Jersey
I"m not gonna post the brand and if you know I would apreciate not syaing so as I want this to be more about the turbo's size and trim and .ar vs brand performance and what not. Below is the stats of the turbo I"m thinking about giving a shot. This will be a car that is street driven 97% of the time but I want to be able to put down 400whp on pump gas. By looking at the size specs of the turbo do you think that is a reasonable goal. If you know a turbo that has comparable stats chime in that woudl make it easier for me to make my descision.
!!!! I have a 420a not a 4g63 motor. I am fully built with high compression motor so spool should be a little faster than a basic 4g63 setup but I will limited in how much boost I can run!!!
Specifications:
Compressor: 50 trim 0.70 A/R
Compressor Inducer: 64.8 mm
Compressor Exducer: 91.4 mm
Compressor Inlet: 4” hose connection
Compressor Outlet: 2.5” hose connection
Turbine: 58 trim 0.63 A/R
Turbine Inducer: 73.4 mm
Turbine Exducer: 55.9 mm
Turbine Inlet: Standard T3 4 bolt flange
Turbine Outlet: 3" 4 bolt round flange
Center Housing: Oil cooled
Bearing System: Journal bearing
Wastegate: External
That's a big turbo. You'll get plenty of lag on the street. Typically, a turbo with a 65mm compressor wheel is a drag race only item. For comparison, a GT35 has a 61mm compressor inducer.
It's odd that the turbine wheel has such a small exducer given the size of the compressor and the size of the turbine inducer. This might help spool a little, but it'll also choke off the overall flow.
That's what I thought and was hoping they have this same turbo with a .48ar hot side too but I felt that would be too small but again this is a street car.
Considering the motor you have, that's way to big. Especially with only a 400 hp limit. If i were you I'd go with something more like a Garrett GT2876R which will have some decent spool up, or, if you want to be able to push a little over 500hp eventually, the Garrett GT3071R, which will also still have decent spool up. On top of that they ball have ball bearing center sections. They still have the same A/R on the turbine side but that won't matter much with ball bearings.
Another thing I'd be worried about running as big of a turbo as you have posted is compressor surge. Definitely keep that in mind. And if your motor is high compression but is built then you don't have to run too low of boost levels.
That made no sense:confused:. WHat do you mean for my motor that's way to big. I have the same displacement as a 4g63 and yes I a built how else would I have high compression pistons?? Neither of the turbo's would do over 500hp without meth or race gas. I want this turbo to make 400whp reliably on pump gas and spool by 4500 by debat enow is to get the .48ar and sacrafice spool or do I hope my higher compression pistons will help a little with spool and get the .63ar and have a much better top end?
This is what I meant. It's too big for street ability. I should have clarified that. If you want street ability then why are you looking at spool up around 4500? You shouldn't ever see that on the street if we're talking about normal every day driving. It's nice to have that for a drag application but look for a spool up around 2500-3500 for really good street ability. This will get you a lot of fun and still be able to hit your mark of 400 hp without a hitch. On top of that, when you do go to the track to race you will get full boost just that much quicker and that can make all the difference in a race...
I meant full boost by 4500. Usualy from my experience a turbo capable of making 400whp on lower boost levels usually hits full boost around 42-4500rpms. Even though I'm built I have 10:5:1 compression which will limit how much boost I can run. I'm aiming for 15psi on pump.
The same company offers this turbo I think this will be a lot better for my goals and it's rated to 500hp.
Specifications:
Compressor: 50 trim 0.50 A/R
Compressor Inducer: 53.5 mm
Compressor Exducer: 75.5 mm
Compressor Inlet: 3.5” hose connection
Turbine: 73 trim 0.63 A/R
Turbine Inducer: 60.8 mm
Turbine Exducer: 52 mm
Turbine Outlet: 2.5" 4 bolt round flange
Wastegate: External
That one looks much better, after all it has the famous 50 trim compressor. The exhaust wheel is a little small, but that's not terrible. The .63 A/R housing should let it flow well.
Yeah I'm worried about it being too small though. But like you said it the pump gas king 50 trim compressor and I'm having Nate tune it for me so I figure if he can get 400 out of a 16g with pump gas this thing can make 400 on pump too.
Ok let me be more reasonable and list the mods in a easy to read form in case my profile is kinda confusing:
97 eclipse GS 420a motor
10:5:1 Weisco Pistons
Eagle H beam rods
Ported and polished head
Obx intake manifold port matched
Q45 TB
Crower Stage 2 3/4 race cams
Crower spring/retainer kit
3" full N1 Style exhaust(no cat)
The main factors that are making this a harder call is teh 10:5:1 compression and stage 2 cams
From talking to SBR and a couple other companies it looks like 15-17psi is the max that can be run without dealing with crazy knock on 10:5:1 compression on pump gas. So unless I get meth injections the turbo I pick has to make the power i'm looing for at those psi levels. I really think meth migt be my only option on this.
Turbo's like low compression better.
If you want pump gas power, then don't get a high compression ratio. It's easier to make power with low engine compression + more boost....... as oppose to high engine compression + less boost.
The Turbo specs you posted is of a pretty big turbo. It'll probably hit 20psi around 5000rpm or later in 3rd or 4th gear. It's too hard to tell just by looking a specs. Try to find a person who has it, and check out the (real world) performance.
I never was a specs guy when it comes to turbo. I can read the specs just fine, but it just dosent seem to add-up as easily..... as oppose to looking at real world performance #'s.
My best advice would be too get your goals together. Do a brain storm about everything you want. Write it down. (sometime the goals just can't mix-match like a person wants them too)
If all you want is 400awhp and good spool..... then I'd say get a 20g. It'll hit quick and hard!
If you want to build for future power (like 500awhp) then get a FP3052.
Something in that area
Also where (at what RPM) a turbo hits full boost is relative.
Full boost in 1st gear? Full boost in 2nd, 3rd, or 4th gear? It makes a big difference.
Currently I have my car set at 24lbs of boost.
My FP3065 will hit about 20lbs in 1st gear, 21lbs in 2nd, 23.5lbs in 3rd, and finally 24lbs in 4th/5th. In each gear the boost comes on at a different RPM. In 3rd gear I see 23+lbs boost around 4500rpm, but in 1st gear I bet I don't get 21lbs until about 5500RPM.... (and can that even be called full boost if I hit 22lbs and its set at 24lbs?)
Theres alot that most people never think about when asking general questions.
My best advice is to really think about what you want. Write it all down, and then look into real world performance, and go with what works:thumb:
Well, your engine is set-up better than mine was when I ran this turbo 2 years ago.
The only issue that I forsee is running that low boost. I was around 27 psi to make 400 WHP.
But he has 10.5:1 compression compared to 8.5:1, I'm guessing he won't need very much more than 20-22psi max to hit 400whp.
Yeah well it looks like it's meth and pump gas for me.
Suggest you use either meth or nitrous, not both. Nitrous has an even greater cooling/condensing effect than meth.
He has Nate lined up to tune it. I don't think tuning will be too much of a problem.
He has a fwd 420a, so awhp and mitsu bolt on turbos aren't really good options for him.
Oops.... I thought you were "going" to get a built 10.5:1 comp motor ....Not "already" have one. My bad.
Are you going to have a custom ext mani built? Thats something to think about. If you're not planning on a custom mani, then that'll narrow the choices down for sure.
Have you considered a 4g63 swap?
If a turbo car is what you want, then its best to have a motor thats built for turbo's. You're probably going to want a 4g63 anyways... after you get the turbo bug.
I bet you could find a complete used 4g63 for a good price (cheaper than your 420a build). It'll have everything you need, and if it's quality, then it won't need a rebuild. It'll handle 400whp easy.
Ok first let me say def thanks for everyone's input always apreciated. I'm not a newb by any means though. I know how to setup a build and see it threw and make it so the parts flow well together. The long block I got with a deal I couldn't turn down thats' why I picked it up with 10:5:1 compression. I knwo with lower compression I would have a easier time. Hell if I had lower compression my turbo selection would be a no brainer but of course it's not. To delta448 I think you misread my post. I didn't say I was getting meth and GAS as in nitrous I said i'm going to be using PUMP GAS as in 93 octane fuel and meth vs race gas. The 10:5:1 block is in my car this isn't a hypothetical thread like you see the newb's post lie how do you think this will go together it already exsist. Literally the last two things I need to chose are wastaget size and turbo.
Cool
What exhaust mani do you have? ....Or are going to get?
That's got alot to do with what turbo will work.
either way.... I still think a 20g (or something comparable) would be great for quick spool and 400whp.
If I decide to keep my EVO1, then I'm getting a 20g for it's 400awhp goal. I think 400 is perfect for the 20g.
((ok ok I'll stop whoring out your thread now)) :coy:
thanks
I don't have any direct experience with high compression + boost, but I'd be surprised to see 400 WHP at less than 40 lb/min airflow.
Also, he already stated this was a pump gas build, and he probably won't be hitting boost levels that high. I don't know what a T3, E-cover 50-trim flows at 18 psi, but I wouldn't think it would be enough airflow to hit roughly 475 crank HP on pump gas.
I shouldn't have assumed, I guess I just remember that you were a nitrous guy, -heck it's even in your signature. Meth is an awesome tool for pump gas tuning.
You're probably right about the airflow required, like I wrote -I was taking a rough guess. You should consider though how much a difference the high CR is going to make. Cylinder pressures will be the same at a lower boost pressure. Although, with 15% drivetrain loss factored in, my first thoughts really do sound ambitious, even maybe for something with a slightly larger compressor.
  • For sale 2g Rear brake rotors and pads for FWD
    Brand new EBC rotors and ProStop Platinum pads. Very good quality OE spec parts. Accidentally...
    • 2GbTalonGuy
  • Wanted 2g black hood
    Does anyone have preferably a black hood for sale let me know need to buy one by this week
    • DSM-kiezerz
  • For sale JMF Coil Pack Bracket
    JMF Coil Pack Bracket. Buyer pays fees/shipping to the lower 48 states. You must be registered...
    • elocneas
  • For sale 2g Eagle talon headlights set
    Talon headlight set no broken tabs
    • Lonestardsm
  • For sale 2g Stock 2G BOV
    Stock plastic 2G BOV. Removed years ago (probably 2001...). Figured someone might want it...
