turbo installation
funniegus
451
3
Jun 5, 2004
Bolingbrook, Illinois
I am going to install a 14b I got off of ebay on my 1g in a couple of weeks. Do I really have to take the exhaust manifold off? Is there any easier way to do it? I really dont want to take the manifold off and risk the chance of breaking the bolts in my head. OMG
maybe you can slide it in from underneath, I did this in an AWD but didnt have a radiator in it and a few other things. If it is that much of a worry there is a way but it may be a lot of pain. My suggestion is bite the bullet, soak the sh*t out of the studs and give them a crack. good luck
with a few tricks youll be fine. i got my b16g in w/o removing the manifold. taking the fans out really helps out. only 8 10mm bolts. good luck
For me;
Remove intake.
Remove DP.
Remove A/C fan.
Remove oil and water lines.
Remove the nut on the turbo stud and washers on the stud. Then do the double nut trick on the stud, back it out the turbo, and completley remove the stud first (PB Blaster, breaker bar, and heat). Then work on the other three bolts and it will drop out without removing the manifold. Removing the stud first is the key.
It worked for me.
