Turbo Install Pics & CEL issues!
Aggression
41
Aug 11, 2002
VA Beach, Virginia
Well first off before you go running off to look at the turbo install pics I need your help.
I installed the turbo and drove it for about 5 minutes. The next day I had to go to work and I got in fired it up and got a cel and a oil light came on. I checked the oil level and its fine, the oil sending unit is plugged in fine, and the I have oil pressure. Could it be a bad sensor and should I just replace the Oil Sending Unit?
The cell was a evap and is probably a loose vacuum line!
I need your advice!
Here are the pics >>> TURBO INSTALL PICS!!!
Well this is what I think...say you were to take it to a garage...they would start by replacing that sensor. So I would do that first. Then go to the next thing inline with that. Trouble shooting sucks. Don't be surpised if you get another cell after you fix that one. Glad to see you got your kit in, looks good.
