Bock
5+ Year Contributor
- 94
- 74
- Jun 13, 2018
St-Jerome,
QC, Canada
Hi, i bought a bunch of parts a few week ago. Came with an oem new (refurbish maybe?) mitsubishi 20g turbo.
Turbo came disassemble, i'm going to put it together with a new rebuild kit and have it balance by a shop.
My question are;
-the compressor housing have 2 bolt screw in the housing(passing thru), Is it Ok or it can cause any restriction? (have a tig welder, can weld to block if its a concern)
-On the compressor housing, there is a tiny hole? like this, its gonna leak, is it for drilling and taping for a vacum nipple? Can i weld it to block the hole?
-On the turbine housing, it still look new (look to have been refurbish, there is an helicoil on the flange and wastegate flap welded) but there is some crack inside, is it still good or no?
Right now i have a small 16g on the car. Was thinking to swap for the 20g if everything is OK. i can used spare part from the s16g if there is something wrong with the 20g (turbine housing).
My question are;
