turbo downpipe
95 gs
Nov 12, 2004
spring hill, Florida
he I have a 420a and I am makeing my own turbo kit I am have a exhaust manifold like the one you git with the hahn kit but where can I git a down pipe like the hahn kit :confused:
HRC now sells a full 3" downpipe. You just need to make sure that you use a turbo that will accommodate the downpipe mounting.
I would buy directly from HRC.
:( I am going with t25 turbo (stock gst turbo) how will the down pipe work with that setup
Well What about this!
Get this from
punishment racing
By the time you weld it turn it 180* degree or so(or let somebody else to weld it. But do it when you have it mont it on the car) because of the space in there.
U can put a big Pipe (if you are runing internal wastegate). If you are runing external wastegate block the small hole and only run the big one. the weld shop should be able to everything (If they are good at it).
Just run your inmaginacion if you know how it works.
and drive the car to a muffler shop and they should be able to custom build a downpipe out of it. I was about to do that as well. I might do it anyway! But that is my opinion.
thanks man I live in sping hill FL I was just at daytona beach last week end for the rod run :D :thumb:
No problem! I hope it helps.
BTW
I hope you enjoyed Daytona beach. You better come back in spring break, It is the crazies thing ever!!
  • For sale 2g Rear brake rotors and pads for FWD
    Brand new EBC rotors and ProStop Platinum pads. Very good quality OE spec parts. Accidentally...
    • 2GbTalonGuy
  • Wanted 2g black hood
    Does anyone have preferably a black hood for sale let me know need to buy one by this week
    • DSM-kiezerz
  • For sale JMF Coil Pack Bracket
    JMF Coil Pack Bracket. Buyer pays fees/shipping to the lower 48 states. You must be registered...
    • elocneas
  • For sale 2g Eagle talon headlights set
    Talon headlight set no broken tabs
    • Lonestardsm
  • For sale 2g Stock 2G BOV
    Stock plastic 2G BOV. Removed years ago (probably 2001...). Figured someone might want it...
