Turbo downpipe questions
The boost creep can be solved by porting. However, you'll be able to run higher boost on an external setup. The internal wastegate will blow open at higher boost levels (~25+ psi).
Yeah, that's why i think im going to go with an external 38mm off the manifold. and have the flapper welded shut. Thanks for the info though :)
