Turbo cooler?
4g63telantra
454
Dec 10, 2004
Toronto,
just wanted to know if anyone has done this or what they think of it
near the valve cover there is the oil pipe that goes into the turbo, just wanted to know what if i hooked up that pipe to a cooler then then run it into the turbo?
well that help my turbo keep cool or there is no point of doing this?
or should i just run it stock like the 90 talons? (oil filter housing)
90 DSMs run oil feed stock from the head not the oil filter housings. There are arguements about feeding from the oil filter housings with the oil pressure it provides. Some say yes, some no.
I wouldn't add another cooler because you may loose oil pressure and it would just add to the possiblities of more oil leaks. Anyone else?
Steve
I thought he was asking if he could add an additional cooler to the stock set up?
k as of now i have no cooler (car is in the shop) and just wanted to know if i can just run a cooler off the turbo and not the oil housing
Its sounds like you want to cool the oil before it goes into the turbo. Waste of time. I've never heard, seen or read about it. As for external oil coolers, yes 90 style housings have ports for a cooler.
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
