turbo clutch and flywheel on nt tranny
bkblazen2003
109
May 19, 2004
brooklyn, New York
i just installed every thing. car will not fully engage clutch. i can't get it in gear. i used a 6 bolt turbo flywheel and stock turbo clutch.
it makes noise when the clutch medal is let go.
doesn't make noise when pedal is pushed in, but wont engage clutch in enough to allow a gear change.
Update your vehicle profile so people can see what your working with, you'll get more replies cause people can actually think and relate based on the car you have and the car they have.
Right now I'm assuming you have 1g NT because you said you put a turbo tranny/clutch on your car. If that is established then I'm sure somone could help you out.
2G clutch/flywheel won't fit on 2GNT cars.
Good luck, sorry I couldn't be of too much help to your actual problem.
thanks alot. guees i'll just throw my new disc on my non turbo pressure plate and change the flywheel.
