turbo 246 crane cams, what can I expect?
GSTurbo1
610
May 2, 2012
Pickens, SC, South Carolina
Ok guys so i'm rebuilding my turbo 420a, built bottom end 8.5 compression JE FSR pistons... yada yada built built. So I had a pair of intake and exhaust 246 crane cams i'm going to drop in on a clean warp free head, what should I expect different from stock?
I'm going from stock cams.
Thanks guys,
Jason
Honestly, not a lot. I had the Crane 12's for a while and honestly didn't make that much of a difference. If you have them laying around, sure use them, but I wouldn't go out and buy them because there are other cams out there that make a difference for the same round about price.
Had the Crowers Stage 2 (don't remember the specs on them or how similar) but had ended up losing some low end power but had a nice kick in the power curve at around 3600rpm. That was before I had turbo. Add the turbo into that mix and it kicked pretty nicely.
