420auser
- 0
- Oct 1, 2006
Cochranville,
Pennsylvania
Hey guys, I am in the process of rebuilding my engine. I will be using the howell automotive 2.2 Stroker kit, although I have decided to take a different route. I am going to be using high compression pistons (12.5:1) and the cams used for high compression. Every thing in the engine is going to be set and and ready for high compression use. I will also be upgrading my intake and fuel setup (36 lbs injectors, fuel rail, pump, ect...) As for my main question, I was wondering if tuning was needed or if the setup would work with out it. If not, would somebody be able to tell me what piggy back system would be best for my setup? Would I be able to just get a fuel controller or would I need the whole system? The tuner I asked said it is very difficult to tune a OBD 2 car, so how would I have it done. And finally, could I get the timing adjusted at the shop with out gettting a new ecu. Thanks a lot, 420auser.
