Tuning My AFC to work with my 550's
xXEclipse
470
Aug 30, 2010
Montrose, California
I have a 1998 GSX With a 1G Swap, 2G Head.. I have 550 Injectors but theyre dumping too much fuel. I think (correct me if im wrong) that the airflow menu is what i need to change? These Are the current settings
1K 2K 3K 4K 5K 6K 7K 8K
-22 -22 -22 -23 -23 -23 -23 -23 = High
-20 -20 -20 -20 -20 -20 -20 -20 = Low
I dont know much someone please help tell me how to tune it to what i need, and also what does hi throttle low throttle mean??
I have stock turbo. Thanks in advanced
Lets say you set the hi-point @ 70%.
-That means @ 70% throttle the AFC will use your hi throttle map.
Lets say you set the lo-point @ 30% throttle.
-That means @ 30% throttle the AFC will use your low throttle map.
If the TPS reads 50%, the AFC compensates and uses the averages of the hi and low map percentages (aka if 4k rpm is -10% Lo, and 4k rpm Hi is +10% the AFC would not add fuel @ 4000RPM @ 50%).
Did I make this understandable? :)
NOTE: GET A WIDEBAND!!
Sometimes a quick google search can help out as well, thats how i found the guide below. *Dont believe everything you read though, and def. invest in a wideband, possibly a datalogger too! Good luck and adjust in small increments that way you don't grenade anything.
RRE's Super AFC Setting and Adjustment Tips
