Tuning help - Pocketlogger Files
Cody D
93
May 26, 2004
Olds, AB, Canada
Hey, I just installed my new EPROM chip set for my 650cc injectors and it seems to be working okay, but I'm getting knock pretty bad that won't go away when the boost really hits at about 4500rpm. Here is a datalog of my run, I was wondering if someone could take a look at it for me, I just am not that good at tuning yet.
These two are pulls from 1st gear through to 3rd gear at 20psi, at about 5500rpm in 3rd gear my car bucks pretty hard:
01 - Save As
02 - Save As
These two are 4th gear pulls at 18psi:
03 - Save As
04 - Save As
My Car:
1993 Eagle Talon TSI AWD
6 bolt block - Balance Shafts Removed
7 bolt head - Stock
K&N Filter w/ 3" inlet
Custom Intake Pipe 3"
Turbonetics T3/T4 Turbo - 60 Trim w/ Stage 3 Exhaust Turbine
Turbonetics Exhaust Manifold
Tial 34mm External Wastegate - Dumped to Atmosphere
3" O2 housing
3" Intercooler piping
Custom FMIC
Turbosmart BOV
3" GM MAF and Translator
3" Throttlebody Elbow
3" Exhaust Turbo back
NGK Plugs and Wires
ECU -Programmed chip for 650cc injectors, Studderbox.
S-AFC 1
Blitz Dual Selonoid Boost Controller
Apexi Turbo Timer
Pocketlogger
AEM Wideband O2 Sensor
EGT Gauge
Rear mounted battery - Taylor box, external kill switch
A/C Removed
