tubular manifold question
jaredgsx
342
8
Mar 9, 2005
evansville, Indiana
How does a tubular manifold increase horse power? It would seem to me that the longer runners would make spool time increase.
Tubulat manifolds also have the gases coming in at a more optimal angle (usually straight at the tubine blades) And usually have more gradual turns.
Quote:
Originally Posted by TheArtist
Paperclip has a point, but the point made actually only is effective when trying to spool larger turbos. The stock manifold works best with t28 and works very well up to the big16g evo III.
"the stock 2g mani will support around 600hp
so its fine way over and beyond a 16g-"
If you took a 900hp dsm and put any EX manifold on there i bet the power wouldn't drop that much!!! All manifolds will support most power levels, it's were you want the power..sooner or later!!! I do agree though if you run a large turbo you should chose the manifold that gives the quickest spool, which in most cases is tubular....having said that, it depends on what you want!!
