TSI With no gears...
MediumJ
Mar 18, 2007
Tulsa, Oklahoma
So my car started slipping when a boosted hard. After I bled the fluid it would drive fine until after 3 or so pulls it would start to slip again. Well a couple days ago I let a buddy drive it , when he brought it back it would not go in any gear. I checked the fluid and it was empty. I added some and rebled it and a mile down the road the car started jerking and jumping and would not go in any gears again. I try bleeding it several times after that and nothing happened. What could this be? I dont think its the tranny cause it never grinded or anything before. But I dont know. Please help!
if the fluid is empty you obviously have a leak some where. i would start by checking for fluid by you clutch pedal lever where it goes thru the fire wall. if you find nothing there start checking over the clutch lines and fittings. check for spots of dirt build up on the lines. usually when a line is leaking dirt will stick to the fluid making it easier to spot.
  • Wanted 6 bolt NT water pipe
    • chrisman287
