TSi Stalls when I give it gas in gear
eccocraft
Mar 15, 2009
Portsmouth, Virginia
First off, I have a 1993 Talon TSi. I recently replaced the starter, the air filter, and spark plugs all at the same time. The car was running great before the starter went out. Now it will crank and idle fine. If I rev on it in idle, the car reacts normally, but when I attempt to give it gas while in gear, it immediately stalls.
Even if the clutch is fully engaged, it still stalls.
Help pls.
Check your spark plug gap. Check to make sure you have the correct firing order on your spark plugs. Did you forget to plug the MAS back in?
