Tru-boost question
Fast95GSX
67
3
Feb 25, 2011
Grand Rapids, Michigan
I'm trying to find a good setting for the Spring crack pressure. I have an adjustable internal wastegate and with the Tru-boost set off, I hit 16psi solid boost. I have slow spoolup and spr set at 10psi.
I bumped up the spr to 11psi and it didn't seem to help much. I probably will have to go higher than that even....
Set your crack pressure to what your actual pressure is. What turbo are you using?
The closer you set it to your actual pressure the faster it should spool and if you want an even faster spool set it a few psi higher but watch for boost spike
Bump the Spr to 15.8psi and it spools up super quick now with no spikes. I now hit 25psi with no problem now....
