InfiniteGSX
- 3,182
- 16
- Dec 10, 2002
Tijeras,
New Mexico
I've looked around and have NOT found one single retrofit with these projectors in our kinda headlights (92+). These projectors were designed to be "bolted" into H4 housings. I was introduced to them by another retrofit guy here on the forums and always wanted some. Picked these guys up for 60 new. I need to break out the dremel because using a hole saw on OEM Headlight Reflectors is a royal PITA. And I already screwed up the first one. However the fix cost me 10 cents. Next one I'm gonna break out the dremel.
I decided to use the OEM Reflectors because the Ebay headlight reflectors aren't "cut". They are just a shiny bowl with a bulb inside them. So they have no professional beam... Not like it matters. I just want to still use the OEM High Beam.
