nickxf250
- 46
- 1
- Dec 1, 2003
I recently changed the timing belt on my 1995 tsi and now the car has developed a slight miss at idle and it seems the the oil pressure gauge is reading slightly higher than normal. If the belt was a little too loose would that cause the car to miss slightly at idle? I changed the plugs and wires but that didn't help. Any ideas on why the oil pressure would be slightly higher? The only reason I did the timing belt is because the water pump went out.
