transmission rebuild question (shimming)
Cesar
519
May 24, 2003
Titusville, Florida
hello,
My question is:
When finding out the end play between the tranny case and bearing races (with solder), is RTV or gasket maker to be used? Usually, what thickness does the material have when torqued to 28ft/lbs?
The reason being is, I'm gonna get my readings with no gasket, then I will apply RTV when I have the proper spacers...
THanks
Cesar.
The rtv will have very little affect on the shimming and a real thin beed is all that is needed .Just make sure you are turning the shafts when you are tighting the bolt when you are getting the readings from the solder to make sure the cone bearings are seated in good during the process .I got some rtv from the Crysler dealer that work real good , it was made for trany fluids .
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
