Eeeeky
- 344
- 4
- Oct 8, 2008
Roosevelt,
Utah
Hey guys and gals! I have a 97 GSX, which before i ripped it all apart for a rebuild, i was driving along, and i had to get on the throttle to avoid a collision, and something in the driveline "Popped" , now it feels as if the clutch is slipping. The car still speeds up, but no where near the way it used to. The speedometer goes as normal, i can do 20 mph sitting in my driveway
, so i know the clutch is fine.It did "kinda" pop back into place, but getting on the gas again soon produced a POP and nearly no go again. I have checked both front CV's, and the half shaft, they all look fine as far as splines, and drive parts go.
The splines on the differential look good, and i ripped into the Transfer case, it is fine as well.
Upon tearing into the trans tonight, i couldnt get the damn case apart, but i did get the end cover off. the gear in the center, had alot of side to side play, but everything has always, and still does shift perfectly I have not yet checked the rear driveline, or rear end parts at all yet. The thing on the inside of that end cover, on the transfer case output shaft, looks to be like a LSD?? it doesnt look hurt at all, but i have no way to get into it to tell. So before i go nuts, and buy a whole new trans, is this a common problem? Is it easily fixable?? What do i do? hehe. Lots of questions, but ill learn one day.
Thanks for the help guys, i really need to figure this out!
Aeryk
, so i know the clutch is fine.It did "kinda" pop back into place, but getting on the gas again soon produced a POP and nearly no go again. I have checked both front CV's, and the half shaft, they all look fine as far as splines, and drive parts go. The splines on the differential look good, and i ripped into the Transfer case, it is fine as well.
Aeryk
