transmission hep
boosted99eclips
Aug 2, 2009
yelm, Washington
99 mitsubishi eclipse gs(420a) with a hahn turbo kit. ok so the last couple months my tranny has been making a wierd like gring noise when the cluth wasdisengaged. but when engaged it went away. ok so thre other dayi did a really hard launch. went to go shift and it was really hard shifting. i pretty much had to shove it into gear. then i drove it and it shifted ok. when i put in the clutch it seemed to stay in gear and in order to getit out i had to rev it up. and ithit hard and came out. next day went to go drive it and it would not go nto gear.. what doyouthink i messed up..
The first series of noises was probably the throw-out bearing grinding. The subsequent issues are most likely the imminent/eventual clutch failure. Either way, you`re pulling the tranny anyway. Just replace it all . . . :talon:
