Transmission empty, bone dry
Spoolin4Ever
1,142
14
Apr 24, 2005
Moses Lake, Washington
Wow I was just going to drain my transmission, which uses a 19 MM wrench for the fill bolt, and a 17mm drain bolt. I got the drain bolt off, and not a drop came out! Strange thing is my transmission was working fine when I last drove the car. Car's been sitting about 4 years. There is a film of oil, bot nothing came out. It was Redline MT90 or something like that, I forget now what it was it been so long.
Anybody else found their transmission dry and it didn't break down?
Even if it didn't break down, the wear on bearings would be substantial.
On a side note are you sure you took the right plugs off? I could've sworn on a 1g the drain plug is 24mm and the fill is 17mm, correct me if I'm wrong
The drain is the huge flat head bolt on the bottom at the end cover (furthest to the wheel). If that wasn't what you took off, then you took the wrong bolt off. There are bolts that hold the linkage, the fork rods and the reverse gear assy so make sure you're removing the correct one.
When we bought by girlfriends 1G and I got it running I idled it a few times before I realized the brand new shep trans it came with had no fluid in it. My stupid fault for not checking it before starting the car but it has been fine. And that trans had supposedly been sitting for a while. So if you do pull the right plug and there is still nothing in it then I wouldn't be too concerned.
