Transmission drain stripped
Scoobystyl
277
Nov 5, 2011
Denver, Colorado
Does anyone have any tips or tricks for getting out the transmission drain plug when its been completely rounded off?
Vice grips couldnt get it to budge, i was thinking about using an extractor socket, but the largest i have is a #13, ill have to look and see if they even make any that large
You don't have a good enough pair of vice grips, or don't know how to use them properly.
. A pair like this will get it if you lock the tight enough and in the right direction. IF you use a pair of cheap off brand vice grips than you will never get it.
I only use the finest, no china tools in my garage. the problem is the head is only 3/16 deep and is also rounded off, theres no clamping on something like that.
Im going to give it a shot tomorrow first with an extractor socket, and if all else fails ill weld a socket to the head
