translab shift kit
The shift kit improves shifting and offers firmer shifting. It prolongs the life of the transmission (more fluid flow and pressure). The stock setup causes softer, slower shifting because it slips the clutches more (less fluid flow and pressure). That actually causes more wear of the clutches. It will be easier for you to buy a valve body with a pre-installed shift kit. It costs more but the work is already done and you won't damage your current valve body.
And where can you order one of those?
i actually just finished all the engine work on my first dsm LOL. (timing belt, water pump,battery, spark plugs/wires, oil,fuel filter etc) It's a 91 laser rs turbo fwd. Picked it up for $450 with only 103k orig miles needs some tlc and paint. but to the point of this post
The tranny is a mess it bangs down hard into second and doesnt shift into overdrive and I'm wanting to build the engine to 300-350hp but am not sure about who makes good rebuild kits and shift kits.. any ideas?
Other than this obvious thread-jack.
Call up IPT. IPT Performance Transmissions Torque Converters and Transmission Parts for Ford, GM, Chrysler, and Import vehicles
They also sell the shift kits both in DIY and already done (send in your valve body as a core).
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
