2G Transfer case output shaft seal
DSM Chase
778
51
Sep 19, 2011
Senoia, Georgia
My T case output shaft seal in the trans is leaking and has spun trans fluid in my bell housing and at times under boost in 5th my clutch would slip (brand new Act 2100). How hard is that seal to replace with trans in the car? And what's the best way to clean my clutch disc off.
Thanks
Relatively easy I should think, from memory you will just need to drop the downpipe, 2 bolts, drop the t-case, 5 bolts, and then you should be able to get to it. Shouldn't take more than an hour or 2 if that. As far as cleaning the fluid off, spray the crap out of it with brake cleaner, use a rag to wipe some of it away if needed, and obv don't get the brake clean in your eyes. Brake clean+eyeballs=pain.
