420A Transaxle side seal
Jacobie
Jan 21, 2023
Sherwood, Oregon
I opened up my trans to do some fixes and I’m trying to find a gasket for this part on the side can anyone help?
I’m assuming you mean the end cover that you took off? If so, if memory serves it’s just black rtv between the case and cover and then properly torquing the bolts.
There is no gasket. Always has just been sealant. I used black RTV on mine multiple times, issue free. I'm sure it had some sort of Mopar sealant from the factory but that's not necessary to use.
In your picture I see fluid on the sealing surface. Make sure you wipe it down with something like isopropyl alcohol before using sealant to ensure it will adhere.
